STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Resolved! TFT Display using NUCLEO-F746ZG
Posted on May 31, 2017 at 18:23Hello!I am a beginner using the the NUCLEO-F746ZG to drive a 4.3' Newhaven TFT display that has a capacitive touch panel controller.The parts are shown below:https://www.digikey.com/product-detail/en/stmicroelectronics...
STemWin issues during linkage?
Posted on July 27, 2017 at 09:49Hi STM32 communityI'm tring to use STemWin in my project. I use IDE eclipse running on windows.I've created a project with STM32cubeMX V1.0 version 4.22 (STM32Cube_FW_F7_V1.7.0 firmware ).After generating the project ...
stm32f429 graphic LCD
Posted on September 05, 2017 at 13:37Hi everyone.I have stm32f429-DISC0 board and I wanted to use graphic LCD. I found the CMSIS workshop series and step by step I did everything as said on the video. But unfortunately after 3th video nothing worked...
mk61 by Associate II
  • 1162 Views
Resolved! JPEG Compression Example
Posted on August 29, 2017 at 12:09I have an array of luminance representing a picture in grayscale. Data are captured using DCMI. I need  to compress these data using JPEG unit available in F7 series, but I can't find any application note describing...
How to use STemWin on IAR 6.40?
Posted on August 28, 2017 at 18:32Hello!I am using STM32437I-EVAL on IAR 6.40 IDE.I am trying to load an example of a project using STemWin library, but when I import the project on IAR, it pops up a dialog box saying 'Broken options were detected o...
Stemwin GUI not working for external SDRAM
Posted on August 21, 2017 at 09:50I have linked STemWin library. My project uses external SDRAMWhen I display some progressbar or treeview or graph using internal RAM, value of progress is displayed correctlly (ex. 50%). Also treeview and graph is d...
Resolved! Using DCMI in interlaced scans
Posted on August 10, 2017 at 08:47I am working on an application which requires interfacing an analog camera. I have choosed TI TVP5150AM1 to decode analog video to YCrCb 4:2:2 format and the scan format will be interlaced. As it has been mention he...
STemWin listview problem
Posted on July 19, 2017 at 10:36Hello,I have some trouble with my listview widget. 1. I can change the column width 'manually' - I mean by touch. Is there a possibility to set it fixed width? I noticed that when I change the width by this way the li...
M Ryb by Associate
  • 1240 Views
