STM32 MCUs Embedded software
Can't make software jump to Bootloader/DFU on STM32F767
I've read various articles/guides how to jump to bootloader form main program (without using boot0 pin and reset). All code that I've tried seems to fail...My current approach is like this:#define BOOTLOADER_ADDR 0x1FF00000U   void (*SysMemBootJump)(...
Nixz by Associate III
  • 6020 Views
  • 15 replies
WFI usage with RTOS
Hi,I am using STM32F779NI and CMSIS RTOS2 for my project. Software was working well till I added code for low power mode with RTOS tick-less operation as per the linkhttps://www.keil.com/pack/doc/CMSIS/RTOS2/html/group__CMSIS__RTOS__KernelCtrl.html#g...
A3 by Associate III
  • 2634 Views
  • 3 replies
Transfer project to new board
Hello!I have a education task. I need to transfer X-CUBE-USB-AUDIO (https://www.st.com/en/embedded-software/x-cube-usb-audio.html) to stm32f746g discovery. Project supports boards STM32446E-EVAL and 32F769IDISCOVERY. I think stm32f746g is similar 32F...
VGuly.1 by Associate
  • 1356 Views
Resolved! Where do you log bugs discovered in the `HAL_`?
I believe I have found a bug in `HAL_I2C_Master_Transmit`.The timeout parameter begins counting from the instant the transaction begins, and it doesn't appear that the watchdog is being reset with each incoming byte. Therefore, when you have a long I...
Zak by Associate II
  • 1655 Views
