STM32 MCUs Embedded software
stm32f746g disco play pcm audio from udp
hii am working on stm32f746 disco board and i want to play audio with board from online udp data. for this target i wrote a qt application to send pcm audio data over udp protocol and in stm32 program i use lwip receive function in a freertos task fo...
Hpott.1 by Associate
  • 1777 Views
  • 1 replies
Resolved! How to transmit non-echo TCP packets using Netx?
HiI must have done something wrong in the function below to transmit a buffer on a tcp socket. If transmitting up to 4096 bytes the function works fine. If len is greater than that, nx_tcp_socket_send fails. How to stream a buffer correctly using Net...
AMend.5 by Associate III
  • 6504 Views
  • 9 replies
Resolved! I am using the USB-PD protocol with the stm32G071RBT6 processor with the tcpp01 card. I can only get 5v at the output(Vbus). I can't get 20v(Vbus). what should I do. APPLICATION NOTE(AN5418) , TCPP01-M12 DOCUMENT AND LINK OF USB-PD CODE BELOW.
BOARDS: STM32G071RBT6,x-nucleo-usbpdm1APPLICATION VIDEO:https://www.youtube.com/watch?v=-vsJhNIaHxEhttps://github.com/mbekirtopal/USB-PD/tree/main/usb_delivery
Mtopa.1 by Associate II
  • 19831 Views
  • 10 replies
Resolved! How to configure I2C speed for STM32H7?
I am looking for a way to change the HAL I2C lib clock speed during runtime to either 100k or 400k or 1M.I tried the following.....hi2c1.Init.ClockSpeed = 100000;However when compiling this the compiler do not recognize the parameter.
fglau by Associate II
  • 6618 Views
  • 7 replies
USB bootloader for STM32F401RE
Hi, I am using stm32f401RE and want to flash the firmware through USB. Is seperate USB bootloader need to be flashed for my usecase or the USB bootloader will already be available in ROM.
KK Y.1 by Associate II
  • 1410 Views
