STM32 MCUs Embedded software
Resolved! Call HAL_ETH_ReleaseTxPacket() from ISR context?
I am connecting a TCP/IP stack to the HAL_ETH driver of an STM32F7xx. I am using https://github.com/STMicroelectronics/STM32CubeF7/blob/master/Projects/STM32F767ZI-Nucleo/Applications/LwIP/LwIP_HTTP_Server_Netconn_RTOS/Src/ethernetif.c as a starting ...
riwe by Associate II
  • 1077 Views
Global Interrupt Disabling in LPTIM_Disable()
Could you please explain why global interrupts are disabled (using __disable_irq()) at the beginning of the LPTIM_Disable() function, and re-enabled at the end?Does this relate to ensuring atomicity during the timer's register save/restore process, p...
Tom_18 by Associate
  • 1017 Views
  • 1 kudos
STM32N6570-DK High Speed USB with DMA
I have USB2 OTG high speed port1 working in "device mode" on the STM32N6570-DK board. I need to transfer an image file (around 10 MBytes in size) from the external PSRAM IC (APS256XXN-OBR-BG Hexadeca‑SPI PSRAM) to external PC via  a bulk CDC IN endpo...
