STM32 MCUs Embedded software
STM32 bootloader form SD card
Posted on August 21, 2015 at 09:04 Hello ! I have a problem with my bootloader form SD card. I think i try everything, now i don't have any ideas. App in sd card have changed memory start address to 0x08002000 and memory size to 0x0003E000. ...
piotr2399 by Associate II
  • 3273 Views
  • 8 replies
stm32 flash problem
Posted on August 21, 2015 at 17:28i am working on stm32f030cc.i implement user boot loader between 0x08000000-0x08003000 and user application onwards.both works fine.i write protect boot loader area.but when power gone and after that when power on d...
karan by Associate III
  • 773 Views
  • 1 replies
STMF429IGT Usb Bootloader AN3990 [SOLVED]
Posted on August 08, 2015 at 23:44 Hello, I'm trying to run this bootloader on a custom board with a 429IG on it. My target application runs fine, but I need to be able to update on site through usb. So far, the bootloader writes the image o...
STM32F407 knowing the bootloader version
Posted on August 20, 2015 at 20:55Hi !I have a question regarding the bootloader versions on my STM32F407xx boards :Is it possible to determin the version of the bootloader a chip contains either from the text printed on the chip or via SWD wires ?M...
ole2399 by Associate
  • 947 Views
  • 1 replies
FreeRTOS Dynamic Memory Management (STM32F4)
Posted on August 19, 2015 at 18:42Please see attachment .pdf to see the content I excluded for brevity. I have a project with various communication stacks. Messages arrive through one port, and may be processed locally, or routed to another port. Ad...
ssmail by Associate II
  • 3818 Views
Ununderstandable HAL enum behaviour
Posted on July 11, 2015 at 07:41 Hello, I have a very simple issue but ununderstandable for me. Hopping someone could explain me what's happening. I have made the code simple in order to point out the issue: #include ''main.h'...
astree by Associate II
  • 1309 Views
  • 1 replies
Understanding boot mode in STM32
Posted on August 19, 2015 at 13:59Hi, I read datasheet STM32F072xx and  AN2606 but I have a lack of understanding what are User Flash memory, System memory and embedded memory boot mode. Does someone could explain me :First of all I don't understand...
  • 4838 Views
  • 5 replies
