STM32 MCUs Embedded software
Understanding boot mode in STM32
Posted on August 19, 2015 at 13:59Hi, I read datasheet STM32F072xx and  AN2606 but I have a lack of understanding what are User Flash memory, System memory and embedded memory boot mode. Does someone could explain me :First of all I don't understand...
astree by Associate II
  • 4843 Views
  • 5 replies
FreeRTOS + TCP in STM32Cube
Posted on August 05, 2015 at 20:57Are there any plans to integrate the FreeRTOS + TCP into STM32Cube?  this would make the LwIP thread aware.  FreeRTOS has the basics but not completed for the STM32 so the level of effort would be moderate but proba...
HAL_Delay in microseconds for NucleoF411RE
Posted on August 17, 2015 at 18:45Hello everyone !! I have a http://www.st.com/web/catalog/tools/FM116/SC959/SS1532/LN1847/PF260320 and use IAR with . How can I implement a delay with HAL in us (microseconds)? Please give us some hints. Best Reg...
Using Newlib in IAR Workbench
Posted on August 18, 2015 at 12:06I am trying to port a project developed using Eclipse for the STM32 Discovery board into IAR Workbench. While trying to compile the project, I have the following error: ''Error[Pe020]: identifier ''_impure_ptr'' is ...
sommer by Associate II
  • 1610 Views
How to use HAL I2C Library
Posted on July 29, 2015 at 11:29Hello, I need to make my STM32F072 communicate with a HIH sensor through I2C.I want to use HAL_I2C_Master_Transmit and HAL_I2C_Master_Receive. For exemple if I just need to generate a write condition bit may I use it ...
  • 4020 Views
  • 7 replies
A bit of advice and CMSIS API document?
Posted on August 13, 2015 at 00:58Hi folks,I've been drowning in mountains of non-useful documentation looking for something very simple:  an API document for CMSIS peripheral functions, written for the application developer (not ARM document detail...
STM32F302 as USB Virtual Com Port Device.
Posted on August 11, 2015 at 13:40I am trying to use STM32Cube to generate a VCP Usb device framework for the STM32F302CB micro.It works fine for a STM32F405 chip and a STM32F103 chip.But on the 302, it just wont enumerate properly?The only differen...
tinymanta by Associate II
  • 1180 Views
  • 1 replies
