stm32 flash problem
karan
Posted on August 21, 2015 at 17:28
i am working on stm32f030cc.i implement user boot loader between 0x08000000-0x08003000 and user application onwards.both works fine.i write protect boot loader area.but when power gone and after that when power on device user application not run.when i read memory through STVP i found that every time section 0x08003000-0x080037FF erased means one sector of my user application erased.in user application i never write eney flash.this should be not happen.....
#stm32f0-flash-loader #stm32 #bootloader
Posted on August 21, 2015 at 17:37
That's why you'll have to spend some time debugging to understand why it's happening.
Check the loader, then the app. Chances are you have an off-by-one in a loop doing the erase. Either you have an errant erase, or a write is not working. Instrument your erase/write code, and verify everything is being written as expected.
Check for EEPROM emulation code.
