STM32 MCUs Boards and hardware tools
Ask questions and find answers on STM32 hardware set-ups, including schematic-related challenges, debugging probes, power configurations, and more.
Resolved! STMF334R8 not found in debug
When I try too start debugging I get this message:I checked the drivers and the device is showing as a USB Composit Device and I have no alternative to change the driver.I installed en.stsw-link009 and successfully installed some drivers but they are...
MLakc.1 by Associate II
  • 5440 Views
  • 13 replies
Technological for soldering question
We plan to use in one of our products WLCSP49 package.Please see page 126(PDF attached) - According to Table 80. "WLCSP49 recommended PCB design rules (0.4 mm pitch)" , the recommended Dpad Dimension is 220 µm.We perform some measurements on the PCB ...
RSaat.1 by Associate
  • 2697 Views
  • 1 replies
How to use STlink-V3 in mass storage mode to program bootloader and main program? How to continuously influence the address from which STlink-V3 programs the FLASH memory?
Hello, We are switching to STlink-V3 as our main debugging and programming tool. For programming, we use the mass-storage interface for simplicity. It works perfectly.The problem is that the mass-storage interface programs the FLASH memory from addre...
vfura.1 by Associate
  • 4951 Views
  • 6 replies
  • 2 kudos
STM32F4 DISCOVERY Board has noisy USART2 when board is powered by external source and USB ST-Link is disconnected.
I have an STM32F4 Discovery board with a USB->Serial converter connected to pins PA2 (TX) and PA3 (RX). I used CubeMX to configure usart2. My test code successfully sends data over usart2 when I power the discovery board as usual over USB.However whe...
LMorr.3 by Senior II
  • 1101 Views
  • 0 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
