STM32 MCUs TouchGFX and GUI
Discuss STM32 and TouchGFX implementations, including configuration, debugging, and optimization.
X-CUBE-TOUCHGFX 4.26.1 is out!
TouchGFX 4.26.1 is now out. Please follow this link to download it.This version is a patch release and includes bugfixes of issues seen on TouchGFX Designer 4.26.1 version, as well as adding support of the new STM32H5F5 and Chrom-ART 2.Please visit o...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
TouchGFX bitmap corrupted data
Hi,I amp developing a touchgfx application on a custom board with a STM32F3. I have got the STM32G0 example as inspiration and i have modified the display driver in order to work with my Ili9341. In first place i am trying to run a short application ...
DCajigal by Associate III
  • 2283 Views
  • 4 replies
Set DisplayRotation to 270
Hi,We have this odd requirement due to LCD mounting limitations on our product. I can run touchgfx UI application with DisplayOrientation set to rotate90. But we want it to be rotate270 to match the lcd mounted on the product. Based on my understandi...
STang.1 by Associate II
  • 2262 Views
  • 5 replies
Resolved! Running TouchGFX on STM32H745I-DISCO
Hello,As TouchGFX does not support STM32H745, I tried the demo program for STM32H750 on this board. It works properly when it is programmed and also after reset (soft reset with button or software). But when I disconnect the power from st-link USB po...
MMokh.1 by Associate II
  • 1520 Views
  • 1 replies
how to Access Other screen image in presence Screen
hii..i am using STM32G474 MCU with Touch GFX Tool for TFT Display Drive and i want to access Other Screen Image/Widget in Present Screen, so please suggest beast way, i have try many times to fill Present Screen container with other Screen Image u...
Sgoti.1 by Associate II
  • 1126 Views
  • 1 replies
