STM32 MCUs Embedded software
Is DFSDM required for PDM mics
Hi - I'm trying to get a single PDM mic (ST MP34DT01-M) working with an STM32H7, using SAI. It's outputting static when I send the DAC each SAI *freq* interrupt. Some questions:Is the DFSDM peripheral required? If so, what does the value of the SAI x...
DOCon.1 by Senior
  • 1174 Views
  • 0 replies
Ethernet transmit descriptor BxL vs FL, treatment of oversized packets bellow 2kb, and D2 memory (STM32H745ZI - RM0399).
B1L/B2L vs FLI'm writing an ethernet driver and the FL field in TDES3 seems to not do anything.I am not setting the TSE bit.The packets seem to always leave with a size that is the sum of both B1L and B2L (if used).In my last test I set it up like so...
Bmen.1 by Associate
  • 1386 Views
  • 0 replies
Resolved! startup-stm32xxx is not nowhere to be found
Hey, I'm currently trying to get myself away from HAL, insteed using a more direct implementation. So the first thing I am trying is a simple blinky programm, with as little as possible number of files. I downloaded the StdPeripherel Files for my boa...
Senax by Associate II
  • 4110 Views
  • 7 replies
