STM32 MCUs Embedded software
AWS FreeRTOS
Hi,I have spent the last two days trying to build a demo application that connects a B-L475E-IOT01A1 to AWS.However, I keep finding that the demos will not build due to it needing an old tool chain.The documentation for the board on how to run AWS Fr...
Jorgie by Associate III
  • 2464 Views
  • 3 replies
  • 3 kudos
Trying to Generate a sbus
[moderation:] Please see How to write your question to maximize your chances to find a solution, How to insert code [/moderation] I am trying to generate a sbus signal for radio transmission in drones. imhave tried this code. in oscilloscope, uart ou...
Examples on STM32U5A9J-DK not compiling
I am trying to flash BSP example from https://github.com/STMicroelectronics/STM32CubeU5/tree/main/Projects esp. the ones for STM32U5A9J-DK. While trying to compile BSP : https://github.com/STMicroelectronics/STM32CubeU5/tree/main/Projects/STM32U5x9J-...
giteshk by Associate
  • 1174 Views
  • 1 kudos
Resolved! USBx MSC Standalone
I'm trying to get USBX MSC working in standalone mode on the STM32H573I Discovery board.I've come across a few tutorials for setting up USBX in VCP  mode and have attempted to adapt them for MSC, but I haven’t been able to get the USB to enumerate pr...
STM32H7 with FatFS on eMMC sometimes failing
Hello everyone,I have a project using the STM32H7, using FreeRTOS and with a FatFS (ChaN) runnin on a 4GB eMMC (Kingston), using peripheral SDMMC1.Normally everything works fine. SDMMC1 and FatFS (FAT32) are initialized at main, before OS, and is use...
TVare.1 by Associate III
  • 15481 Views
  • 24 replies
Resolved! STM32U5 - USB and FreeRTOS?
I'm starting a project on the STM32U5G9, and one feature we want is USB connectivity, just a simple virtual COM port (CDC class).  Looking at the Middleware picker in CubeMX, the only USB-related items are USBPD (don't need Power Delivery at the mome...
dmarks-ls by Associate III
  • 6498 Views
  • 12 replies
  • 9 kudos
processor goes to HardFault at __ISB
Hello, I've bought Riverdi board and I'm developing a code that uses Ethernet and act as TCP server.   The code sends "Hello word %d", i++ every 10ms on that TCP socket and it works fine,   but when I try to send some byte on client size it goes to H...
