STM32 MCUs Embedded software
STM32G070 Flash Library for Bootloader
I would like to write a bootloader for STM32G070 which I can use across projects. Is there any flash library for STM32G070 available which I can use and write a bootloader? OR does STM32G070 has inbuilt bootloader which I can call by sending respect...
GSing.1 by Associate
  • 1549 Views
  • 1 replies
Questions surrounding __HAL_LOCK
Posted on April 26, 2016 at 00:12 I’m an engineer at Fluke, and we’re using an STM32F4xx seriesmicrocontroller (together with its HAL drivers) as the basis for a newproduct. The HAL contains a “locking�? mechanism, where eachsubsystem—I²C, USB, ...
Resolved! USB noise appears with -O0 optimization
Hi,I'm trying to certified a product and we just fail the ETSI EMC. It appears that the USB lines are the cause of this failure. As we tried to track down the main source of this issue it appears that between 2 differents firmware the noise level was...
STM32F746NG USB OTG Host Device Mode
Hi,Is there any example showing how to configure STM32F746NG-discovery USB to be in DRD mode?I found examples for F1, F2, F4 but not for F7. The drivers used on these are not availible for F7.In CubeMX when i select USB_OTG_FS mode to OTG/Dual_Role_D...
JProc.1 by Associate
  • 568 Views
  • 0 replies
How to use STM32 USB Device Audio Streaming software expansion for STM32Cube software package with STM32CubeIDE
Hi,I am looking into application development which should have USB audio streaming in a customized board.I have downloaded the X-CUBE-USB-AUDIO software extension package from ST.com. Can anyone help me how to use along with STM32CubeIDE tool.Regards...
