STM32 MCUs Embedded software
H7 MCU usb OTG host mode
I am using H7 MCU's usb OTG in host only mode. I try to directly power the VBus by on board 5V without power switch. That means VBUS is always on after power the board. Is it support by H7's USB OTG?
JZou.2 by Associate II
  • 1042 Views
How to interface the FTDI USB device??
Hi, Everyone?I'm googling a couple of days to find clue of interfacing the FTDI USB device to my USB host service. But, I cannot find any solution like cool sparking water.​I'm using STM32F207VE with STM32CubeIDE. I know that FTDI does not use CDC se...
paul0208 by Associate III
  • 5825 Views
  • 3 replies
Resolved! STM32F429 Discovery - firmware update from USB drive
bootloader update the application saved on the USB memory stick attached to on STM32F429 Discovery board when reset occurs, it detects if USB flash memory pen is attached, if attached read and copy application file (hexfile) from usb and update If re...
MAlkh.1 by Associate II
  • 2311 Views
  • 4 replies
STM32F107 LwIP TCP server stops transmitting
Hello!I'm writing a small application based on Cube LwIP TCP echo server example little adapted to my custom board. The application is sending small periodic reports (50-150 bytes) to connected TCP client but on some iteration it stops transmitting m...
IOrek.1 by Associate II
  • 1995 Views
  • 3 replies
Anybody has the slide decks for this course - https://www.youtube.com/watch?v=Pr3L4-H3ClQ&list=PLBvX9IPnj5MRFS3jyQ-2uwflSAV7KYv5b
Hi, I have been looking for STM32 Ethernet peripheral course. I found a YouTube link - https://www.youtube.com/watch?v=Pr3L4-H3ClQ&list=PLBvX9IPnj5MRFS3jyQ-2uwflSAV7KYv5b but it is not in english. Does any of you has the slide deck used in the cours...
HSing.2 by Associate
  • 762 Views
  • 1 replies
