STM32 MCUs Boards and hardware tools
Ask questions and find answers on STM32 hardware set-ups, including schematic-related challenges, debugging probes, power configurations, and more.
connecting STM32 BL475E IoT01A to a HC 05
I want to pair the STM32 BL475E IoT01A to a HC05 module connected to another STM32F401ccu6 to send data to the IoT board.But when I tried to do so,I'm not able to find the pairing key anywhere.I tried 0000,1234,1111 but that didnt work.Is there any o...
Priyaa by Associate II
  • 896 Views
  • 0 replies
Resolved! Smart vision with STM32H743ZI2
In the context of a research project, I am using the STM32H743ZI2 microcontroller for object detection. However, I lack prior experience with camera interfacing and configuration. I am using a B-CAMS-OMV camera module. Therefore, I would be grateful ...
Resolved! Static addr of I3C in H563ZIT6
I have a H563ZIT6 . I attach its I3C(used as target) to an I3C controller, and then i find that there is no register for static address in target mode in I3C of H563ZIT6, i just find DEVR0 for dynamic address. Does I3C of H563ZIT6 support static addr...
Xonier by Associate III
  • 2091 Views
  • 1 kudos
GPIOB3 is enable while STLINK is running
Hi everyone,I am running en.x-cube-spin14 sample code for X-NUCLEO-IHM14A1 (STSPIN820 stepper motor driver) on a nucleo64 board with STM32F411REBefore any move of the stepper motor this code is executed: if (HAL_GPIO_ReadPin(BSP_MOTOR_CONTROL_BOARD_...
Resolved! Nucleo ST Link bricked in CUBEIDE
Hi,tried to update the ST-Link Firmware on my NUCLEO-F429ZI as requested by STM32CubeIDE. Updating failed and the board is no longer recognized as a USB device. The COM LED (LD4) on the ST-Link section blinks red.Is there a way to resurrect the firmw...
tschwarz by Associate II
  • 4196 Views
  • 5 replies
  • 6 kudos
Resolved! Why does CAN_TI0R_TXRQ fails to set?
Hello,I am trying to communicate between two NUCLEO-F446ZE boards using the CAN protocol. To obtain this, I am basing myself on this video (https://www.youtube.com/watch?v=HYgYN0IEoNc&ab_channel=ASKEDISON%2CDOIT), although my code is a little differe...
DriesVR94 by Associate II
  • 1499 Views
  • 1 replies
