STM32 MCUs Embedded software
Resolved! HAL_I2S_Receive gives 0s although codec transmits data
Hello!For a week i've been trying to configure my stm32f302cbt6 and the tlv320aic3254 codec to trasmit data to the mcu through i2s_ext_sd but HAL_I2S_Receive returns 0s to the buffer although i see data coming out of the codec. I have configured i2s2...
PPats.1 by Associate III
  • 4736 Views
  • 7 replies
Flash Erase on STM32G4 doesn't work as intended
I'm running a STM32G473CB with 128kb flash, and I'm getting some issues erasing pages in bank2 of the flash. Using HAL_FLASHEx_Erase the way it's meant to be used, like in the following code that's supposed to erase pages 30 and 31 of bank2, I don't ...
schwil by Associate II
  • 3716 Views
  • 5 replies
Resolved! STM32G0B USB error during initialization, SOLVED by modifying your library
in usb library in the file generated by STM32CubeMx for the STM32G0B1 * @file          : Target/usbd_conf.c * @version       : v3.0_Cube * @brief         : This file implements the board support package for the USB device libraryin function void HAL_...
GPREV.1 by Associate II
  • 1863 Views
  • 2 kudos
Update MCU firmware (RMII and external flash)
Hello,I own a Nucleo-H723 and I would like to know how to update the MCU firmware using the ethernet port to transfer data. I want to send the bin/hex file over TCP (LwIP) and store the file in a external flash (QSPI), as I am not sure that the MCU f...
inigo1 by Associate II
  • 2915 Views
  • 4 replies
Resolved! FAQ: Error flashing Zephyr firmware with STLINK-V3MINI (SWD) by openocd runner in steval_stwinkt1 dev kit.
I tried to flash Zephyr Firmware by DFU and I the firmware flashed as I expected.In the other hand, I tried flashing firmware by STLINK-V3MINI something raise an error.This is the contents of board.cmake file:# west flash -r openocd   # west flash -r...
RArte.1 by Associate II
  • 2999 Views
  • 1 replies
What is the register behavior of "rw_wt"?
I'm trying to understand the register behavior of rw_wt.In the RM0090, Ethernet DMA transmit poll demand register (ETH_DMATPDR) has a register. this register declared as "rw_wt". But I don't know how rw_wt work.Could you please clarify the register b...
