STM32 MCUs Embedded software
Recover after failed USB DFU
Hello,when I was Upgrading firmware (dfu) it got failed due to some bug in my code and the device moved to an unresponsive state is there any way to recover the device with USB ..MCU: STM32L476.Access: Only USB.thanks in advance
SLinux by Associate
  • 1123 Views
  • 1 replies
How to combine USB HID with DFU?
Hi,Do anyone know how to combine USB HID with DFU?What I would like to achieve, a custom HID class that is able to get update using the USB connection.MCU: STM32G473RET6
TA.1 by Associate II
  • 3462 Views
  • 5 replies
SD does not work on STM32L4S9ZIT6
I have followed this examplehttps://community.st.com/s/article/how-to-create-a-file-system-on-a-sd-card-using-stm32bubeideI got this setup on STM32F746G-DISCO and it is working fine. I cannot get it working on custom board with STM32L4S9ZIT6. I wonde...
_legacyfs_online_stmicro_images_0693W00000biB5IQAU.png _legacyfs_online_stmicro_images_0693W00000biB5DQAU.png
MNapi by Senior III
  • 820 Views
  • 0 replies
Dual Bank boot in STM32U585
Hello Support Team.We are considering MCU STM32U585(TrustZone) as per our product requirements. It contains Ultra-low-power Arm Cortex-M33 processor.Our application contains safety-critical and non-safety-critical code.We will provide CRC of safety-c...
JShah.7 by Associate III
  • 2061 Views
  • 1 replies
Resolved! Assign Static IP address in Threadx
Greetings !I am working on STM32H743 EVK and I could successfully compiled and executed the sample TCP Echo Server application over Threadx . But here DHCP IP is assigning . Please help me out to make IP as static IP.Thanks in Advance
PG.9 by Associate III
  • 2522 Views
