STM32 MCUs Embedded software
Resolved! Netx secure client authentication
I am using Netx secure for TLS implementation.here my requirement is to establish a TLS connection with mutual authentication (client and server).I am able to establish the proper handshake with Mutual authentication but the problem is when I try to ...
sabari1 by Associate III
  • 1874 Views
  • 1 replies
Resolved! STM32WB55 Thread Undefined Reference To Errors
Hi,I'm trying to debug new thread ftd project. You can find my settings below:   - HSEM - IPCC - RCC -> HSE/LSE - SYS -> Serial wire - RTC - LPUART1 & LPUART1 DMA - USART1 & USART1 DMA - RF - STM32_WPAN as a THREAD   When I debug it, It gives me a li...
Resolved! STM32G031K8 ADC Vref INT
Hi, I am trying to measure the Vref+ voltage using the ADC on the STM32G031K8. I looked at the latest datasheet saying that the VREF CAL value is the memory adress given below.   So, when I run this code through the debugger,1.) It gives me a hard fa...
External FLASH Memory with STM
I am Interface the External FLASH memory with STM MCU.As per Data sheet All command Implemented on Software But what next i can do not understand.Can You please suggest me any example code of External FLASH Memory with STM MCU using SPI communication...
YShah.1 by Associate II
  • 3844 Views
Resolved! A question on use timer and samples out
Good morning everyone,I'm at my first experience with STM and between guides and tutorials I'm learning many things.But I wanted to configure a 32bit TIM5 timer on my STM32F446 board, I would like my timer to calculate a sample every 0.000001s, only ...
Daddi by Associate
  • 1827 Views
Resolved! RTC values don't change, although alarm is working
Hello,I am trying to use the RTC on a F401CCU6, but the values of the RTC don't change, and stay to what values I've set them in the IOC. I'm using the following function to get the time, and I read the values in the debugger. RTC_TimeTypeDef sTime;H...
Nescada by Associate
  • 2204 Views
Resolved! Changing PWM Mode during runtime
Hello, I am trying to write a routine, that takes an array of structures as input and sets the timer 1 parameters. This function is called after each overflow of timer 1. I turn off the respective channels, then set the parameters, as seen in the fol...
