STM32 MCUs Embedded software
Issue with MX_JPEG_Init Blocking on STM32N6DK750
Hello,I’m trying to add the JPEG encoder to be able to save images in JPEG format to the SD card.While debugging with LEDs, I noticed that MX_JPEG_Init blocks the program, whereas HPDMA is working correctly.I have added all the necessary files for JP...
HMTb by Associate II
  • 253 Views
  • 3 replies
Development tools for external loaders
I have developed a custom board for STM32F469NIH6 and is loosely based on STM32F469i-DISCO, it uses an external QSPI Flash memory type MT25QL128A as does the DISCO board. For this setup I am using ST supplied external loader MT25QL128A_STM32F469I-DK....
STM32L496 Errata 2.19.4 Not Addressed In HAL
I created an issue on github here,  but wanted to post here as well for visibility.Copied below are the details of this linked content: Describe the set-upCustom hardware for our internal product.STM32L496.HAL version 1.13.5.2 devices on I2C bus, HTU...
Matt001k by Associate
  • 300 Views
  • 2 kudos
Resolved! NUCLEO-U575ZI-Q - HAL_GetTick returns 0
Bonjour,J'utilise la suite CUBEMX et CUBEIDE  pour créer mon projet à partir d'une carte de développement NUCLEO-U575ZI-Q.J'ai réalisé mon projet sur CUBEMX en gardant et validant le BSP de la NUCLEO pour utiliser les leds et surtout le debug via ST-...
CLC_EricF by Associate II
  • 964 Views
  • 23 replies
  • 5 kudos
