STM32 MCUs Embedded software
How do I program the NVM without the Nucleo board?
I'd like to understand how my application can update the NVM for in field programming. It seems the NVM address range is from 0xC0 to 0xE8 but this isn't shown in the register map published with the software libraries. The datasheet mentions a custo...
tkerby by Associate
  • 1557 Views
  • 1 replies
  • 1 kudos
How to use F746NG-DISCO and USB OTG_HS
HelloI want to send 45 Mbyte/sec data from the discovery board to PC . So I need to use usb high-speed protocol (CDC). But PC doesn't find the device (I've checked it via the device manager). I used the CubeMX for code generation.What I simply did is...
Cevdet by Associate III
  • 3666 Views
  • 6 replies
How set USB-CDC (Virtual Com Port) baudrate
Posted on July 07, 2016 at 18:47Hello, I'd like to transfer some data via USB FS with Virtual Com Port (STM32F3) Seems that baudrate is fixed to 115200 bps. It is possible to increase this value? How? Thank you very much #stm32 #cdc #baudrate #vc...
lrosadev by Associate II
  • 9093 Views
  • 4 replies
