STM32 MCUs Embedded software
USB composite CDC + DFU
I would like to use DFU and CDC composite USB devices on STM32L433.Implemented USB descriptors to support DFU and CDC.However DFU was not enumerated properly.Looks like this is USB driver issue.Depending on PID,DFU is enumerated or not.i.e.In case PI...
YChun.15 by Associate
  • 1034 Views
  • 0 replies
  • 1 kudos
Add FreeRTOS to Discovery Node IoT Kit
Has anyone added FreeRTOS to the discovery node iot kit?I've ported freertos several times before (and have donei t on the Nucleo f411) without issue...but it is getting hung up as I try to get it set up with the discovery kit.I am setting the sys ti...
DSabo by Associate III
  • 864 Views
  • 1 replies
SPI bootloader fails to accept every other command.
I am trying to use the SPI bootloader on a Nucleo F446ZE board and have problems when issuing commands. The symptom is that every other command is not acknowledge and every other works fine. Trying for instance the GET_VERSION command gives the follo...
THamb by Associate II
  • 3994 Views
  • 8 replies
STM32 Composite Device
Hi there,i am working on a composite device with STM32F4 and i got it working.I get in the device manager a MSC device and a serial com port. The issue now is i can't open the com port with any terminal program it doesn't respond.Anyone have experien...
arduo by Senior
  • 1982 Views
  • 3 replies
