STM32 MCUs Embedded software
CubeMX USB CDC wrong buffer handling?
Posted on May 26, 2015 at 22:13Hello, in my earlier post I asked abouot buffer handling. I investigated any further and found one potential error and one unused buffer. 1) buffer overflow in file usbd_cdc_if.c &sharpdefine APP_RX_DATA_SIZE  4 ... ui...
taraben by Senior
  • 766 Views
  • 0 replies
STM32F072 DFU vs. App
Posted on April 18, 2015 at 23:21Hi All, I'm new on STM controllers and I don't know enough about this controller yet. I tried to use USB DFU on Discovery board. I using latest DfuSe 3.0.4 and latest STM32Cube_FW_F0_V1.2.0\Projects\STM32F072B-Discov...
anagy9 by Associate II
  • 3439 Views
  • 10 replies
New HAL_UART API
Posted on April 22, 2015 at 19:16In the good old SPL we just had UART_Init, UART_SendData (to send 1 byte) and UART_RecieveData (to receive 1 byte). All interrupt handlers and DMA operation was our own problem.And many of us already wrote them and t...
amomum by Associate III
  • 5239 Views
  • 14 replies
STM32Cube bugs?
Posted on April 19, 2014 at 14:27I started using the STM32Cube using for now the STM32F401 discovery board and Keil software. I like the setup very much as it can make initialization a breeze. However I have a few comments(bugs?). - If I use the FRE...
Fatfs write problem
Posted on May 21, 2015 at 17:59HelloI use STM3210e-eval.I want to implement Fatfs for the SDcard (using SDIO interface)Thats work !I can create a file or a directory, read a file, write in the file, delete file, rename file.the problem is that: when...
Custom bootloader for STM32F407XX
Posted on May 21, 2015 at 11:03I am new to this. May I know how to develop custom bootloader for STM32F407xx? Is there any sample code exists or any document exists which helps me in developing custom bootloader for STM32F407xx? #custom-bootloade...
smanjula by Associate
  • 1242 Views
HAL_I2C_Slave_Receive_IT Abort
Posted on May 21, 2015 at 13:08Hello,I'm using the CubeMXF1 Library for the STM32F103 to act as a I2C slave. This slave is usually in Slave Receive Mode. The I2C master is signaled trough a interrupt pin that the slave wants to send something. How c...
joppe by Associate
  • 897 Views
  • 0 replies
Lwip send udp packets larger than MTU
Posted on May 16, 2015 at 15:27Dear Forum,I bring forth a probably trivial question yet I'm uncertain how to approach it.Using ST STM32F427, RTOS, lwip and sending data over UDP, If I try to send data small than the MTU: e.g: netbuf_ref(buf, dataPoi...
ariel2 by Associate II
  • 1582 Views
  • 1 replies
Flash loader demonstrator for STM 32f407
Posted on April 03, 2012 at 17:02Hi, I was wondering if I could use the Flash Loader Demonstrator to upload and download to the flash memory of the STM32f407. I checked on the website for SW demos under the STM32f407 and didn't find any software tha...
