STM32 MCUs Embedded software
2 UART running in FreeRTOS
Posted on April 07, 2016 at 15:11Hi, I use 2 UART ports: UART1 for WiFi and UART4 for debug output. My goal is to send to UART4 data I received on UART1. When I use only 1 UART, it works (UART4), everything I typed on keyboard, returned back. I impl...
UART
Posted on April 02, 2016 at 12:40Hi,I am facing some weird problem in UART.Whenever i am using UART in polling to receive the data followed by storing the data into some array. But what is happening is that the array is sometimes(mostly) starts to f...
bhavesh by Associate II
  • 2343 Views
  • 4 replies
STM32L0 - DFU support?
Posted on February 21, 2015 at 19:40Hello I just need a confirmation. Is there really no support for firmware upgrade over USB (DFU) in the STM32L0 MCUs??? The STM32L0 is not listed in the http://www.st.com/st-web-ui/static/active/en/resource/techni...
Tantalum by Associate II
  • 1674 Views
Bug when I plug a USB device
Posted on April 01, 2016 at 16:05 Hi, I'm facing trouble when I try to connect a USB device (whatever it is) to my http://www.st.com/web/en/catalog/tools/PF260320. As I plug it, my program is stuck here : Here is a little co...
quentin23 by Associate II
  • 2201 Views
  • 4 replies
STM32F107 with LWIP using CubeMX
Posted on March 21, 2016 at 19:59I've created nearly identical projects using CubeMX.First one is using STM32F107, 2 ADCs, ETH. When I compile it and run on my target (EasyMX Pro v7 for STM32 ARM), it gets to main loop without problems.The only diff...
STM32F7 Discovery USB FS CDC Host demo
Posted on March 24, 2016 at 13:11Having problems getting this to work. I discovered that optimisation may have been the cause of a couple of errors. So, if I turn off all optimisation in SW4STM32 (eclipse IDE + gcc toolchain), I can get the F7 disco...
tau by Associate II
  • 1528 Views
STM32L053R8 as USB mass storage
Posted on March 19, 2016 at 20:50Hello, I am newbie in STM microcotrollers family. Other HelloWorld project work's fine. Now I have new project, I would like show data from memory on microcontroller on my PC. I created project in STMCubeMX then buil...
mocnikg by Associate II
  • 4103 Views
  • 7 replies
