usb audio endpoint single buffer possible?
Posted on June 10, 2016 at 05:54Anyone tried before USB audio playback with endpoint single buffer only? or must double buffer?reason is I use STM32F072 and it's USB buffer only 1K. My device will have playback and recording at 48KHz 24bits. So if must be double buffer I will exceed 1K limitation. #usb #audio #audio #audio #usb #device #usb
