STM32 MCUs Embedded software
STM32f4 discorvery, fatfs, SD card problem
Posted on March 29, 2018 at 15:54Hi all,I'm working on getting a discovery board working with an SD card. I'm using CubeMx v4.25.0 with package v1.21.0.Hardware connection is validated and is correct. I run into a problem when I try to open a file. ...
JOK K by Associate
  • 1297 Views
  • 5 replies
Trying STM32f407 DFU. no luck
Posted on April 25, 2018 at 07:29Hello! I'm trying to get DFU works on our customized board.I tried to use internal DFU Bootloader, using BOOT0, BOOT1 pinsI connected some pins and made BOOT0  HIGH, BOOT1 LOW and plugged in USB Cable, No Luck!Comput...
How to enable USB HHID mouse external feature..?
Posted on April 25, 2018 at 06:340https://electronics.stackexchange.com/questions/370577/how-to-enable-usb-hhid-mouse-external-feature i am using this product Smart Cat PRO MOUSE(GP415U-5321), i am attached to my STM32 evaluation board. Normal opera...
Jesu by Associate II
  • 784 Views
  • 0 replies
Ethernet Rx Interrupt Issue on STM32F4
Posted on April 24, 2018 at 03:32I am currently using a STM32F407 board, with ethernet enabled in Interrupt mode, for the most part it works fine for UDP , I have the STM communicating to a another device via UDP using a switch, and in response to t...
HAL_ppp_MspInit in library project
Posted on April 24, 2018 at 15:00Hi guys,I've just started working on an ST32F4 mcu, with the ST32F429I DISCOVERY demo board.Just one question about HAL_ppp_MspInit() functions: can they be implemented in a source file of a library project?I've trie...
stm32 hal library warning with C++14
Posted on November 30, 2017 at 23:33Hi all,I am using stm32 HAL library in a project with C++14 enabled. It issues me the following warning which I can't get rid of.../platform/stm32/l4/STM32L4xx_HAL_Driver/Inc/stm32l4xx_hal_rcc.h:735:57:warning: co...
Mixing HAL and LL for STM32F446
Posted on April 22, 2018 at 14:39Hi there!I have a bit of code, which was initialized using CubeMX and now I want to use a mix of HAL and LL (use LL for transmitting, use HAL for everything else). Currently I have tried to generate CubeMX code and j...
