STM32 MCUs Embedded software
stm32f4 USB Host HID to interface touchpad..?
Posted on April 12, 2018 at 10:59�We are trying to develop a USB Host HID application where using the controller STM32F4, and the USB stack library available on the ST website, we are trying to send data/command to an USB HID device. But in the libr...
Jesu by Associate II
  • 2544 Views
  • 5 replies
lwIp netconn API UDP connection
Posted on April 27, 2018 at 08:28please tell me more about UDP PORT:- this is my code:-(Is it correct or not)void StartDefaultTask(void const * argument){ /* init code for LWIP */ MX_LWIP_Init();/* USER CODE BEGIN 5 */ /* conn = netconn_new( NETCONN...
Changing the Sensor Pin on STM32F091VCx
Posted on April 25, 2018 at 21:05Hello,I want to know if there is any way to reallocate a sensor configured on a pin from STM32F091VCx to another pin.I have a wind direction sensor that originally was digital and had all the measurement, treatment a...
FreeRTOS and HAL
Posted on September 15, 2017 at 10:11I'm learning how to use an RTOS (FreeRTOS in this case) and I have a couple of questions about its interoperability with HAL. So now I have a project generated by STM32CubeMX v4.22.1 with FreeRTOS selected and so...
USB virtualCOM with STM32F769 Discovery
Posted on March 13, 2017 at 15:09Hi,I am beginning with STM32 MCUs, more concretely with STM32F769NI. I have a STM32F769 Discovery board to make tests. My first attempt was to use the USB from the board to communicate with a PC.Looking for info abou...
Transmission not working with USB HOST CDC using the STM USB stack, STM32CubeMX, the dev board B-L475E-IOT01A (STM32L475 Discovery Kit)
Posted on April 11, 2018 at 21:30I installed the USB HOST CDC on B-L475E-IOT01A, used the STM USB stack and I followed the UM1720 User manual STM32Cube USB host library. When I connect a USB CDC device, everything goes well for the enumeration and c...
STM32-MP3NL/DEC libraries
Posted on April 25, 2018 at 20:10Where to download STM32-MP3NL/DEC libraries?http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-library-expansion/stm32-mp3nl-dec.ht...
Send multi-packet data with USB Host library
Posted on December 02, 2015 at 18:22Hi, I'm using the STM32F407 with USB Host library, in high-speed. I want to communicate via USB with a smartphone. When i send a packet of 64 bytes everything works. If I send a packet, for example, of 94 bytes, t...
vlr by Associate II
  • 1299 Views
  • 1 replies
