STM32 MCUs Embedded software
USB compound device (hub) possible?
Posted on June 09, 2018 at 04:37I need to make a compound device, that's a multifunction device which looks like a hub with some devices behind it.  This is needed to work around a dumb host which does not understand composite devices.Is it possible...
Pavel A. by Super User
  • 925 Views
  • 0 replies
Resolved! Firmware Update RAM requirements
Posted on June 08, 2018 at 16:22I'm looking to do some firmware updates over CAN bus on an M0 based part (possibly F091) which it looks like will require a custom bootloader. Do I need to pick a part with enough RAM to store the entire firmware imag...
Konami by Senior II
  • 2788 Views
  • 5 replies
STM32F0 HAL Firmware 1.0.9 Usb bug
Posted on June 01, 2018 at 02:34Hi,I am new to forum posting and I don't really know how to start ....It's been a while since I wanted to give the HAL drivers a chance and every time ... I get disappointed. My guess is that they use their interns to...
How to measure frequency using Timers
Posted on June 05, 2018 at 22:30Hello guys.When I used LPC17xx series in my last experience of ARM MCUs I used 2 timers one for generating interrupt every 1 second and one for counting the rising edges of the input CAP.So I started reading the Refer...
STSM-LINK009 driver issue Windows 10
Posted on May 30, 2018 at 19:16I downloaded the STSM-Link009 driver and extracted the zip file content to a folder on my C:\ drive. ran the 64-bit .exe file. Everything seemed to install correctly. I have a Windows 10 64-bit OS. I then connected my ...
Could you please tell me to array to string?
Posted on May 17, 2018 at 04:07Dear All;   I would like to know when I have array and I would like to convert array to string.char A[6] = { 'A', 'B', 'C', 'D', 'E', 'F', 'G' };char *B;I would like to *B = 'ABCDEFG';How should I do?#c #hal
Gz by Senior
  • 1742 Views
  • 4 replies
