Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
How to activate an e-SIM on SIM7600
Hi, I am using a SIM7600 and a SIM card to get cellular connectivity. Now I would want to use an e-SIM instead of the SIM card holder. However I cant find information regarding if ST Electronics e-SIMs could use any cellular network provider or if it...
MCrespo by Associate
  • 8004 Views
What is the ESD Rating of STKNX IC?
We have used the STKNX IC in our Product as transceiver. In the ESD Test, the IC failed to sustain. The layout and components of the peripheral circuit is as per datasheet and reference from EVALSTKNX Board. Please guide urgently.
SV.11 by Associate II
  • 4065 Views
  • 6 replies
Resolved! ST4SIM-200M eSIM profile configuration
Hi everyone, In my company, we are currently working on the IOT solution that implements ST4SIM-200M module on our PCB. To shorten things up, we are using SIMCOM modem with the psychical SIM card and it's working ok as we expected. Our next step was ...
S2-LP automatic ACK
I’m testing S2-LP sub-GHz transceivers in stack packet mode. I’m encountering an issue where the sequence number in ACK packets sent by the receiver doesn’t seem to be populated correctly. If I’m not mistaken, when automatic acknowledgment is request...
pelgrimo by Associate II
  • 690 Views
  • 0 replies
Chip ID
Posted on March 22, 2018 at 05:25I have an interface product have some chips carry ST logo, but I can not find anything use the Chip ID. They are EZ026 and EZ030. Can anyone help to identify what is these chips? Here is the picture shows the chip.Th...
Resolved! STKNX Linear regulator dropout
Hi,I would like the DC/DC converter of STKNX to make 5V.Also, I want the Linear regulator to make 3.3VBecause of global efficiency, I wanted to power the linear regulator with the 5V output of DC/DC converter.I'm surprised that the datasheet specifie...
potting BLUENRG-M2SP and BLUENRG-M2SA
Hello,I hope you are well.I am using your bluetooth modules with chip antenna “BLUENRG-M2SA” and PCB antenna “BLUENRG-M2SP”.I'm going to put the 2 modules in the potting ? is there an influence of potting on the characteristics (range, transmission, ...
ljm by Associate III
  • 1435 Views
  • 3 replies
