Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
STuW81300 - SPI Configuration
Hi, I am using STM32L412RB MCU and I need to configure STuW81300 - EVB using SPI. I need an example code for reference. Suggest any relevant examples or programming manuals. Any example of this same or any SPI implementation of STuW81300 would be ver...
VSASI1 by Associate II
  • 1283 Views
  • 1 replies
BlueNRG disconnection
I'm testing BlueNRG-M0L with BlueNRG_chat example:I connect it to my smartphone but I have continuous random disconnection.Is there a timeout setting? Or update FW? With serial port I read:HWver 49, FWver 1840BLE Stack Initialized.SERVER: BLE Stack I...
PPrei by Associate II
  • 1188 Views
  • 1 replies
Transmitter Test of BlueNRG-MS
Hi Everyone,I'm using STM32L4 microcontroller to communicate with BlueNRG-MS over SPI. I'm trying to create a firmware to get FCC certification and one of the parameter testing in that is Duty cycle (verification of spectrum/max energy in 1 MHz span)...
rshar.21 by Associate II
  • 659 Views
  • 0 replies
S2-LP range test
Hello,I am trying to evaluate S2-LP. I have tried a couple of example codes to make one device send packets and another to received packet. I use default settings, whatever the settings of S2-LP in the projects are. I used the S2-LP DK GUI to ensure ...
Witek by Associate II
  • 830 Views
  • 0 replies
LPAd for Linux
Hi, I am looking for an LPAd (Local Profile Assistant - Device) for Linux to manage eSIM profiles on a Linux-based system. Does ST provide an LPAd solution for Linux, or could you recommend a compatible alternative? I am currently trying to download ...
friis by Associate
  • 768 Views
  • 0 replies
