Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Android scanning of BleNRG1 advertiser.
Hi Sir, I am working with BluenrgMS stack all things are well with ios but android BLE apps are unable to scan bluenrg devices.I have tried every solution posted in this community, but none works.why it is so only with android.
s2-lp narrowband settings
Hi EnricoCan you please suggest us the correct values for data rate, deviation and channel filter for the sp-l2 in a narrowband application?How narrow can we go?Also in your schematic you use a trimmer for calibration .Why? Isn’t the tcxo precise eno...
Mmila.9 by Associate II
  • 1856 Views
  • 3 replies
Manual Control of VBUS_EN_SNK of STUSB4500?
Hi,we want to have a possibility to disconnect the USB-C supply manually.Can we use the VBUS_EN_SNK signal and disable the corresponding mosfet manually?The datasheet is somehow unspecific.Is the VBUS_EN_SNK signal undriven when we set the device via...
