PeterChen
How to connect different device use Contiki UDP Sub-GHz
  • July 31, 2019
  • 0 replies
  • 542 views
I have 1 Gateway and 2 devices(A and B).
I use example UDP-sender and UDP-receiver to try implement my project.
The gateway(Sender) with 2 devices(Receiver) communication is OK use Sub-Ghz.
But if my gateway first communicate device A then I change IP address and try communicate device B it's doesn't work, my device B can trigger interrupt but the unicast-receiver doesn't work.
Where am i wrong?
thanks everyone.​
