Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
OTA to another OTA application
Hi,I am developing firmware for an application where in I need to perform an OTA to a higher version (better performance version for instance) and this can keep on continuing, such that I can always update to a higher version from a previous version ...
Resolved! Firmware upgrade over the air.
Hello community,I got a project to do as my Master Thesis on Firmware upgrade over the air.I know how to write linker script, bootloader check free space and configure every peripheral etc. What attributes one look for when working with firmware upgr...
Vmere.1 by Senior
  • 1168 Views
Ultrasound solution and details
Hi,We are looking for 64-channel ultrasound solution for medical imaging. I found your proposal as in the block diagram, as well as the ICs, like STHV64SW and STHV1600. However, I need much more details in order to move forwards. Do you have the full...
LZhan.13 by Associate
  • 809 Views
  • 0 replies
HI, I use DSP28335 to read the rtc M41T94 chip time, the mode is (00 or 11), but the oscilloscope decoding always returns FF or 00. Hope to get your help. thanks ZGH
The DSP28335 processor is used to communicate with the M41T94 real-time clock chip (RTC). The RTC uses SPI for communication. The basic configuration method is to write command + write time, then read command + read time, but the read time is basical...
GZhan.6 by Associate
  • 947 Views
  • 0 replies
