STM32 MCUs Embedded software
STM32F4, High speed MSC problem
Posted on August 29, 2012 at 02:35hello everyonesetup : keil developpement board (MCBSTM32F400, STM32F407) CPU Clock : 168Mhz from HSE. USB Speed : High speed USB Class : MSC - mass storage device ULPI : STULPI01BI use STM32F105/7, STM32F2 and STM32...
haruyama by Associate
  • 975 Views
  • 0 replies
Getting chip ID using DFU bootloader
Posted on August 21, 2012 at 21:33Hello. I have a question about getting chip ID (like 0x0411=STM32F2xx) using buil-in DFU bootloader (USB). There is command get ID in USART protocol, but I don't find equivalent command in DFU protocol. I found only...
kinovicf by Associate II
  • 1590 Views
  • 3 replies
Stack Problem
Posted on January 06, 2012 at 15:31Hi,I have stm32f103rb6 chip. Im trying to implement PolarSSL Crypto Library. But when i try to use library functions, this error occurs ''The stack pointer for stack 'CSTACK' (currently 0x1FFF7E60) is outside the s...
Modifying HID sample for 64Byte IN and OUT reports
Posted on August 21, 2012 at 15:29I was trying to add OUT report to existing HID mouse sample on STM OTG Device library 2.1.0. I am using STM3241G-EVAL.Here are my descriptors... 0x09, /* bLength: Configuration Descriptor size */  USB_CONFIGURATION_...
rishi2 by Associate III
  • 856 Views
  • 0 replies
STM32F415RG hid usb sample does not enumerate ...
Posted on August 09, 2012 at 09:56I am trying to use STM32F415RG OTG HS core in FS device mode but was not able to successfully enumerate it. I am using stm32_f105-07_f2_f4_usb-host-device_lib(2.1) HID sample.I have some confusions like :1. I assume...
  • 3080 Views
  • 9 replies
STM32F4 AUDIO INTERFACE
Posted on August 09, 2012 at 15:50Hi,I am trying to use beep generator function provided by CS43L22 on STM32F4 DISCOVERY.I want to generate continuous beep and listen that on headphone, Here's the code that I've tried for that. I got no error while ...
USB (VCP) disconnect problem - STM32F207ZE
Posted on August 07, 2012 at 12:11I have got the VCP Example from STM32 USB OTG HOST-DEVICE library running on my STM32F207ZE. The example was pasted into my project with small modification - it don't get data from UART port, but application simply ...
konoppo by Associate II
  • 1088 Views
  • 1 replies
Bootloader Flash write issue
Posted on August 06, 2012 at 12:08Hi,We are having some issues with previously validated bootloader code on an STM32F103RG processor.What is strange is that the bootloader is responding correctly to all commands that we are sending to it, and yet it...
dclark9 by Associate II
  • 1930 Views
  • 3 replies
STM32F4-Discovery USB Mass storage
Posted on August 02, 2012 at 15:25Hi, My company is in a phaze where we evaluate STM32F4xx using STM32F4-Discovery EVB. For the past few days we tried to activate USB mass storage feature bug failed. We couldn't find any example for that issue. Can ...
eran2 by Associate II
  • 5626 Views
  • 16 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
