STM32 MCUs Embedded software
STM32F207 low level ethernet driver documentation
Posted on August 18, 2014 at 05:35Hi, Does anyone know if further documentation is available for the Stm32F2x7 low level Ethernet Driver as used in the STSW-STM32060 / AN3384 LwIP TCP/IP stack demonstration for STM32F2x7xx microcontrollers.  The AN3...
martin by Associate II
  • 903 Views
  • 0 replies
STM32F429xx/39xx Native Bootloader
Posted on August 13, 2014 at 16:18Hello guys,Ive been looking into the STM32F429xx/39xx native bootloader.To serve as a guide, here are the steps to be able to use the native bootloader:1. Jump to BTL mode, in this MCU version the best way (personal...
afduarte by Associate II
  • 2724 Views
  • 7 replies
USB_FS SendReport data loss
Posted on August 13, 2014 at 13:32Hi,While I'm trying to send some test value through USB (using USBD_HID_SendReport -> comes from STCube library) first few data is being lost but I don't know while.Here are my descriptor:HID_DEV_ReportDesc[HID_DEV_...
licencje1 by Associate II
  • 1332 Views
  • 4 replies
USB_FS Endpoint IN/OUT addresses
Posted on August 12, 2014 at 15:40Hi,Could somebody tell me where may I find some information about range of addresses of endpoints? In reference manual for stm32f4 I find out that there are ontly 3 in/out endpoints.In example application IN endpoin...
  • 1754 Views
MSC BOT state machine problem
Posted on November 05, 2012 at 07:45 Hi, I have been using the the MSD class driver for usb host on an STM32f4 board. The host seems to work fine for some time, but after say 200 read/write ops it gets stuck at: void USBH_Process(.......
tavish by Associate II
  • 1477 Views
STM32F4 composite USB device
Posted on August 06, 2014 at 10:12 Hi, I'd like to implement a composite USB device with MSC + a custom class. I'm using a STM32428I-EVAL board and some code generated by STMCube. MSC alone is working (with bulk endpoint 0x8...
franck by Associate II
  • 1084 Views
  • 1 replies
Hal bug using rtos
Posted on August 05, 2014 at 12:50I imported an example with  RTOS (FatFs_uSD_RTOS) and I found some bug. In function HAL_Init() is called HAL_SYSTICK_Config()  but  SysTick_Handler()  call xPortSysTickHandler() before osKernelStart() so we have an ...
