STM32 MCUs Embedded software
STM32F746 Webserver files loaded from SD card
Posted on May 21, 2017 at 13:36Hello, I want to create a webserver application, and I want my html file modified seperately. So I think that saving my web files (including .html, .css and .js files) into SD card I a good solution, So whenever I want...
Timer in SDRAM
Posted on March 13, 2018 at 12:58Hi All, I am working on stm32f779i eval board with system work bench IDE, I am fatfs_uSD_RTOS example project in SDK_V1.8.0. I am able to create a timer in this project and make it work, But when I changed RAM to SDR...
uCLinux on STM32F429I-DISCO
Posted on November 13, 2013 at 10:54Hi everybody,I was very happy to see uCLinux port for Cortex-M4 and my favorite MCU STM32. This well done job was achieved by emcraft. So I wonder that is it possible to run uCLinux on my new toy STM32F429I-DISCO?...
tmkaran by Associate II
  • 25296 Views
  • 65 replies
Cube Description and Installation
Posted on March 12, 2018 at 12:05I have returned to stm after several years away.  On my return I find many things changed, for the better by the look of things.  I am a self taught amateur and I find myself ignorant of much here.  I wanted to use c...
MIDI by UART - Library for STM32
Posted on March 11, 2018 at 22:22Hi all!I'm looking for a C library for MIDI communication over UART, in order to use standard DIN connectors.I found many topics about MIDI-USB midibut I can't find any library for MIDI using UARTs.Could you please s...
My code is not entering in while loop
Posted on March 11, 2018 at 09:10The STM32F103C8 is throwing an error it is repeating the code from main loop again and again and not entering inside While loop. I am also unable to debug it in attolic studio since it is showing an error also. I hav...
STM32H743 ADC DMA performance calculations
Posted on March 09, 2018 at 06:42So I am working with an STM32H743 MCU. I have it setup so I am using ADC1 to do a continuous sample of channel 3 and 10 over DMA. All works fine and I get a dma interrupt for conversion complete every ~10 usec. Howev...
