RS485 3.3V or 5V IC For Larger Distance
Hello, Our application needs longer distance RS485 communication, So, From 3.3V and 5V RS485 IC (available in ST), which to choose for larger distance coverage?Thank You
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Hi,I wanna use an RF Transceiver 433khz with STM32 boards and I am looking for the best choices. My requirements are very simple:Frequecy supported 433MhzMultihoping strategySPI interfaceI found the nRF905 but I am looking for a better solution.Thank...
I knew that ST202 is compatible for ST3232. So I changed only ST202 into ST3232 without any circuit changing.But ST3232 doesn't work.What is different between ST3232 and ST202, other than power supply voltage?I found the difference in typical appli...
We are using BlueNRG2 chip for our BLE application. For the Information,We have connected 32MHz external crystal oscillator in HS Pins..We haven't connected any external crystal oscillator at LS Pins..And we haven't connected any inductor at SMPS pin...
I've connected the cno410 LED Driver to NUCLEO-F446RE which works with SPI lines, whenever I've linked to it directly, it works as expected. we have designed another PCB shield on the Nucleo board. On top of we have connected this LED Driver now. Now...
But some time Mcu is unable to read vl53l1 .Do anyone has faced, such issues with the chip, appreciated.
Hi everyone,I am developing a simple scanner using the BLUENRG-M0 from ST. I have a custom board wtih an MSP430F5255I just want to make multiple scan to discover other device of interest around.I am following the ACI API from ST and my first scan is ...
Dear Team, I have Bluenrg-2 devlopment kit and STSW-BLUETILE-DK 1.3.0 SDK. I am using Keil-ARM, compiler V6.19. now I have runed sample project BLE_SensorDemo and others sample projects also getting error:../../../../../Library/SDK_Eval_BlueNRG1/src/...
Hi Team,I am using stm32l475vg MCU and board is B-L475EIOT01.If I create sensor demo project with BlueNRG-1 then it is working properly but If I create same project same configuration with BlueNRG-2 then it is not working.It is stuck in here for Blu...
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
