Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Is there a document that describes the Python data types for events received by the BlueNRG GUI script?
I have a device sending notifications to a BlueNRG-2 Eval board (STEVAL-IDB008V2) configured as central/master. I modified the script file ATT_MTU_extended_packet_len_Master_Security.py to work with my device. Everything works until I receive a notif...
rdscliff by Associate II
  • 820 Views
  • 0 replies
BlueNRG-2 broadcasting
Hello,I have a few questions regarding the use of the BlueNRG-2 deviceI am building a system where I have to send small data packets (10 bytes) from 1 unit to 10+ units. I am aware that you can only have 7 simultaneous connections, but I am wondering...
JFall.1 by Associate
  • 1608 Views
  • 1 kudos
Using TPM in a new product and chose the ST33HTPH20xxAHC3 part for the design. Chip is labeled 'V2' marked on the IC (Can send picture). In addition, we found the FW in the IC changed from 74.9 to 74.65.
Hello Support,We selected the following TPM to design into a new product and chose the ST33HTPH20xxAHC3 part for the design. The product is a specialized Android tablet that is mounted outside conference rooms for room scheduling. We are now entering...
CGett by Associate
  • 899 Views
  • 0 replies
The 'Evt_Blue_Gatt_Attribute_modified' isn't called (is slow) for each received ble message (change of characteristics message)?
I am trying to do a file transfer over ble, using 20 byte characteristics writes. I did notice that, following a write command for characteristic, the resultant aci_gatt_attribute_modified_event() doesnt get called quick enough to process the next in...
TSane.1 by Associate II
  • 820 Views
  • 0 replies
