Hi All, I'm using Bluenrg in one of my project. The pins selected for debugging is SWD pins.Is it possible to use these SWD pins as debug pins in the time of debugging/programming and as GPIO pin in the rest of the code ?
RJOY.1
Winfred LU
Surely you can.
But you will need to be more careful when configuring these IOs. And you may need an alternate way (instead SWD) to debug the applications for these IOs.
It can be confusing for other people co-working together.
