STM32 MCUs Embedded software
USB enumeration failed !
Posted on December 14, 2015 at 17:16Hi, \STM32Cube_FW_F3_V1.4.0\Middlewares\ST\STM32_USB_Device_Library\Core\Src\usbd_core.c (version V2.4.1) The last update with ''Prepare endpoint for premature end of transfer'' modification doesn't work. I had ...
thln47 by Associate III
  • 805 Views
  • 0 replies
bug on STM32_USB_Device_Library
Posted on December 08, 2015 at 10:20Hi, I found another bug on USB library for the STM32F3XX (STM32_USB_Device_Library in STM32Cube_FW_F3_V1.3.0). STM32Cube_FW_F3_V1.3.0\Middlewares\ST\STM32_USB_Device_Library\Core\Src\usbd_core.c In the usbd_core.c...
  • 808 Views
  • 1 replies
Error in stm32f3xx_hal.h
Posted on December 10, 2015 at 15:15Into HAL driver V1.2.0/November-2015 not defined standard type declarations. Insert include file stdint.h in stm32f3xx_hal.h to solve this problem.In System Workbench, compiler and maker not cancel building proces...
mistake in stm32f3xx_hal_pcd.c
Posted on December 08, 2015 at 10:56Hi, STM32Cube_FW_F3_V1.3.0\Drivers\STM32F3xx_HAL_Driver\Src\stm32f3xx_hal_pcd.c In the function below: static HAL_StatusTypeDef PCD_EP_ISR_Handler(PCD_HandleTypeDef *hpcd)     ... line 455:         /*multi-packet ...
  • 964 Views
  • 1 replies
