STM32 MCUs Embedded software
USB CDC by STM32f767zi
Posted on August 04, 2016 at 18:57 I have Nucleo board with STM32f767zi MCU. I use STM32CubeMX and Atollic TrueStudio for ARM. I want to use CDC to communicate with PC. First, the code is not working. I changed the stack size to 2000 and heap ...
mohsen by Associate II
  • 814 Views
  • 0 replies
Analog Watchdog ADC STM32F4 Discovery HAL example
Posted on August 03, 2016 at 18:49Hello,    I want to work with Analog Watchdog ADC of  STM32F4 Discovery using HAL Library. Can anyone please help me where i can find an example or if can someone upload. Thanks in advance! #hal-library #stm32f4-...
ninad911 by Associate III
  • 1312 Views
  • 1 replies
USART DMA Rx for ESP8266 module
Posted on August 03, 2016 at 10:48 Hi All, Well, I started playing with a ESP8266-01 module with the latest firmware AT Expressive. Now I did communicate a STM32L476 (UART 115200 which is the default baud rate of ESP8266). I use a code g...
RomainR. by ST Employee
  • 2784 Views
  • 3 replies
STM32F4 USB OTG Mass storage in FS mode.
Posted on November 19, 2013 at 11:10I have an STM32F4 design that currently uses a FAT formatted uSD to store firmware binary images and text logs. I managed to get this working a while back by modifying Clive1's uSD examples on the F4 discovery.My ...
kobus by Associate II
  • 5075 Views
  • 8 replies
STM32F4 Original Bootloader corrupted?
Posted on August 02, 2016 at 17:57Hi everyone,I was programming my STM32F405RGT6 and can no longer communicate with the board. It appears as a DFU device once I jump the boot pins, but will not appear otherwise. My drivers should not have changed, I...
STM32CubeMX Audio Class
Posted on April 17, 2015 at 12:13Dear all, I'm trying to use STM32CubeMX software to have a starting point to realize a device like an USB Sound Card recognized by PC and able to play a music stream (as development board I'm using the STM32F4 Discov...
aressia by Associate II
  • 2144 Views
  • 4 replies
How to Set USB CDC Line Coding?
Posted on August 02, 2016 at 05:11Using STM32CubeMX 4.16.0  I generated a project with the USB_DEVICE Communication Device Class option enabled. In the document at: http://www.st.com/content/ccc/resource/technical/document/user_manual/b8/5a/28/c2/c...
spflanze by Associate II
  • 1977 Views
  • 1 replies
