Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Hello, I am using libraries available from ST for developing applications based on S2-LP module. I would like to be able to reach a communication distance between 2 devices that is at least 1 KM. I am attaching my current radio configuration. BR
/* Defines ---------------------------------------------------------------*/#define XTAL_OFFSET_PPM       0#define INFINITE_TIMEOUT      0.0#define BASE_FREQUENCY       868.0e6#define CHANNEL_SPACE        100e3#define CHANNEL_NUMBER       0#define DA...
How do I add filtered.c files using the WISE IDE?
I develop my projects based on BlueNRG-LP_LPS DK 1.2.0​,I open any demo and find that only part of the HAL driver is added to the link, but I need to use another driver and don't know how to add it ?​in the ​BlueNRG-LP_LPS DK 1.2.0\Drivers\Periphera...
elv.1 by Associate II
  • 972 Views
  • 0 replies
Sending TXT files through uart
Hi,I'm trying to know how can I send a txt file through UART protocol to a Bluetooth module so I can transfer data wirelessly to a pc.I could read line by line sending it continuously, but I wanted to know if I could send it as a file that I could th...
jreis.1 by Associate II
  • 3786 Views
  • 4 replies
I am doing i2c code with multiple slaves but one of slaves which is vcsel laser driver only contain 11 bit, 3 for address and eight memory I have no idea how to communicate and tell it to emit laser. I am trying to use memory address 001b.
datasheet: https://www.ti.com/lit/ds/symlink/onet4291va.pdf?HQS=dis-mous-null-mousermode-dsf-pf-null-wwe&ts=1665641656738&ref_url=https%253A%252F%252Fwww.mouser.com%252F
ACart.1 by Associate III
  • 3656 Views
  • 8 replies
Difference between STUSB1600QTR vs STUSB1600AQTR?
Hi,As STUSB1600AQTR is currently out of stock everywhere, we have sourced from a secondary source the STUSB1600QTR part number. The datasheets seem almost identical, so we expected the part to be a drop-in replacement. However, this is not the case a...
RTsch.2 by Associate
  • 1373 Views
  • 1 replies
