Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Difference between STUSB1600QTR vs STUSB1600AQTR?
Hi,As STUSB1600AQTR is currently out of stock everywhere, we have sourced from a secondary source the STUSB1600QTR part number. The datasheets seem almost identical, so we expected the part to be a drop-in replacement. However, this is not the case a...
RTsch.2 by Associate
  • 1342 Views
  • 1 replies
VBUS monitoring not working on STUSB1602
Hi guys ! I am trying to implement a USB-C powering and communication between 2 of my devices. There is no Power Negociation implemented yet. The default voltage is 5V.I want to make sure my source device is safe so I would like it to shut down VBUS ...
VSpad.1 by Associate II
  • 1414 Views
  • 1 replies
STUSB4500
Can the STUSB4500 support a USB C DRP and USB PD (sink-only) application using the SOM OTG interface illustrated above? Can it drive the VBUS, OC, and ID inputs and receive the EN output? We would like our product to serve as USB UFP (device), USB DF...
EHD by Associate II
  • 1216 Views
  • 1 replies
LE coded PHY devices compatibility?
Anyone aware if iPhones/ Androids accepting LE coded PHY?If so, starting at which versions do they start working? I saw some info dating from 2020 or early 2021 so I'm wondering if someone has a more recent answer.
CHoul.1 by Associate
  • 783 Views
  • 0 replies
