Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
SPWF01xx more info on TLS handling?
Posted on October 28, 2016 at 01:38HelloI'm evaluating the SPWF01SA for an industrial application especially with regard to its TLS capabilities.Unfortunately my knowledge of TLS especially in an embedded setting is limited, and AN4683 neglects to m...
SPIRIT1 RSSI Filter Gain
Posted on October 19, 2016 at 15:46Hi,I am doing some measurements using the RSSI from the SPIRIT1. I am making the the following test:In the transmiter I am using the continuos wave In the receiver I am verifing the RSSI as the following:Enter RX s...
Saving Settings Without Damaging Flash
Posted on October 13, 2016 at 21:18Hi guys,SPWF01S is a new module for me.  I have been using it for about a month.My question is this: if I set the WiFi connection options at every boot and issue an AT&W (save), will it wear out the eprom memory?  ...
SPWF01S Test mode
Posted on October 18, 2016 at 14:17Hi, UM1695 mentions that there is a special test mode that is enabled via configuration variable ''eft_mode''. Description says ''Enable/disable the Engineering Test Functions. It is used for controlling the radio ...
jarno2 by Associate II
  • 765 Views
  • 1 replies
Unavailable programming manual??
Posted on October 03, 2016 at 13:49Dear all,I have already posted /public/STe2ecommunities/mcu/Lists/STM32Java/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/Where%20to%20find%20a%20programming%20manual&FolderCTID...
Command Mode for Server Socket
Posted on October 14, 2016 at 23:55I have a server socket that automatically goes into data mode when a client connects.I would like to be able to go back to command mode by using the escape sequence ''at+s.'', but it doesn't work, even if I set a c...
