BlueNRG how to use debug?
pawel
Posted on June 17, 2016 at 14:07
Dear Community,
I am trying to use PRINT macro available in BLE1 examples pack (SensorDemo). Is there a way to turn serial communication with the device, as turning DEBUG definition on doesn't allow any COM output?
Thank you,
Pawe?
#bluenrg-serial-com
pawel
Posted on June 29, 2016 at 10:38
I have found out that uncommenting #define DEBUG 1 in SensorDemo was causing the system to lock. I guess that is ST's coding style that if a definition is commented it shall remain commented while when it is set zero than can be changed to 1. Regards,
Pawel
