Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
SPWF04 File print Not Responding
Posted on March 28, 2018 at 17:00I have been able to use the File Print (AT+S.FSP) in some test situations, but now that I'm using it for real I'm not getting any results.When I was performing my feasibility tests I was printing sections from within...
Resolved! SPWF01SA custom HTTP POST request Problem!
Posted on March 15, 2018 at 07:44Hello and good day!I'm attempting to use the SPWF01SA module with an STM32F0 microcontroller to post some data onto a remote web server. I have come to understand that the  AT+S.HTTPPOST command can only post form da...
Resolved! BlueNRG-MS OTA
Posted on March 29, 2018 at 19:19Hello,I'm trying to figure out whether it is possible or not to upgrade the firmware of a host processor connected to BlueNRG-MS.From this http://www.st.com/en/embedded-software/st-blue-dfu.html it seems possible:'Th...
mickael2 by Associate II
  • 1282 Views
  • 1 replies
SPWF04S Power Management
Posted on March 28, 2018 at 17:09I'm looking at the SPWF04 training course which is very good by the way, but it mentions I should refer to 'SPWF04S Power management Application Notes' for more details on the Low power modes.Been unable to find this...
SPIRIT1 interrupt status register bits
Posted on March 28, 2018 at 13:58Hi!My SPIRIT1 code is not working properly and I found confusing the description of the INTERRUPT_MASK and INTERRUPT_STATUS registers in the SPIRIT1 datasheet (rev 10, Oct 2016). In the registers description both MAS...
+WIND:5:WiFi Hardware Failure:5
Posted on July 26, 2016 at 19:08I am consistently getting this error (+WIND:5:WiFi Hardware Failure:5) and I don't understand why? It is a pain because the module keeps having to be reset and it is impossible to communicate on a socket since this ke...
jhousley by Associate II
  • 3100 Views
  • 10 replies
micropython informations
Posted on February 22, 2018 at 21:28 HI, I try to get mySPWF04SAworking with micropython only. 1) I want to be able to connect to my router and send information on MQTT when connected. I have set the console_enables=2 and python_script=m...
jdumaresq by Associate II
  • 1599 Views
Confirmation Update
Posted on March 20, 2018 at 15:26Hello,Having connected two bluenrg-1 devices, if I send a new update value from the slave to the master, is there any way of receiving a confirmation from the master to the slave when I send that new value to know if...
jampino by Associate III
  • 2195 Views
  • 4 replies
SPBT3.0DP2 Firware upgrade not working.
Posted on December 08, 2017 at 12:33Hi,We are able communicate to SPBT3.0DP2 module through UART. we are interested in downloading the new firmware to the Bluetooth module and hence we followed the steps given in the document ''SPBT3.0DPx BT moduleF...
NTP question on SPWF04Sx
Posted on March 26, 2018 at 08:26hi,wifi module spwf04sx (FW1.1.0) in STA mode, connected to PC with NTP server (with wifi).variable ip_ntp_startup set to '1'. variable ip_use_dhcpc set to '1'.To receive message +WIND:84 i should set variable ip_ntp...
