STuW81200 / 81300 Synthesizer. To use the internal registers to control Hardware Power Down should the physical hardware power down pin (Pin 4) be left floating?
David Witts
Posted on November 09, 2017 at 10:51
I wish to use the internal registers of the STuW81300 synthesizer to control the hardware power down function.
Should I leave the physical pin (pin 4) floating or pull it up / down?
There is no mention in the data sheet.
Gerardo GALLUCCI
Posted on November 10, 2017 at 18:58
This is the Wi-Fi modules forum...
