Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Getting DAC output via I2S line
Hello, I want to send data to the DAC with the I2S protocol (assume we are sending an array) and see a sine wave at the output.At this point, I would like to ask: Does the DAC in the stm32f407vg model mean the CS43L22 IC or an internal DAC unit in it...
aozba.1 by Associate II
  • 784 Views
  • 0 replies
Setting up extended advertising with BlueNRG-LP
Hi,I'm trying to setup a client & server pair that work like the following:Server using coded PHY, advertising its device name/manufacturer data in Secondary advertisement channels. That means it will advertise with ADV_EXT_IND in Primary channels fi...
JLee.46 by Associate II
  • 1413 Views
Incorrect reset behavior SPIRIT1
I am using a SPIRIT1 as a transmitterI switch the (2.8v) rail onI wait for the part to become ready (as indicated on GPIO0)I then program it.On MOST samples this is OK, but about one in ten units intermittently fail to program correctly (the SMPS doe...
MDorm.1 by Associate
  • 734 Views
  • 0 replies
