Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
Spirit1 - manchester encoding
Posted on December 21, 2015 at 11:26Hello,I'm trying to decode/encode my packets using manchester code. Is it possible to use on-chip encoding and decoding for this IC? I couldn't find any register in datasheet, so I assume it's not possible but may...
SPWF01S UI Network Configuration
Posted on December 27, 2015 at 12:02I have set my new SPWF01S module up and connected it to my chosen wifi network using AT commands via a terminal at my PC. Obviously this is not very end user friendly, so I wondered rather than writing a UI which ...
SPWF01S Apache Connection
Posted on December 27, 2015 at 11:57I have been following the https://my.st.com//public/STe2ecommunities/interface/Lists/WiFi%20Modules/Attachments/186/wifi%20Training%20-%20Hands%20On%20-%20FW3.3.pdf and I would like to connect to my SPWF01S via ap...
listen udp packet problem
Posted on December 14, 2015 at 15:24Hi.I am trying to listen udp broadcast packets from server but no data received.My st module is station configured and its possible to ping in both direction.  Server Wireshark frame : IP Source       IP Destinati...
emerson by Associate
  • 1247 Views
  • 1 replies
CAPS field on at+s.scan command response
Posted on December 14, 2015 at 17:27Does anyone know what the ''CAPS'' number means on an at+s.scan response?For instance : ''CAPS: 0431 WPA WPA2 WPS'' - what's the 0431 mean?  I'm assuming it's some kind of code field for the security, dhcp whateve...
no data on udp
Posted on October 08, 2015 at 12:08Hello, i have a device, thats streaming data on udp Port 23. I want to read this data with a SPWF01S. The device creates a Network with no encryption in adhoc-mode (channel 11) I used the following to get a connec...
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
