Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
BlueNRG-LP support for LE Audio
Documentation says that the BlueNRG-LP is certified for Bluetooth 5.2 but it does not make mention of isochronous channels/LE Audio support. Is LE Audio supported? Is there a stack that supports LE Audio?Regards,AC
ACoad.1 by Associate II
  • 1154 Views
Help choosing a Bluetooth Module and dev tools
Hello, We are looking to upgrade a customers product line by adding a per-qualified BLE module. We have identified the BLUENRG-M0A as a candidate module. We only need to support HID mode. And SPI or serial is an acceptable interface. However we find...
bartj1 by Associate III
  • 1128 Views
  • 1 replies
  • 1 kudos
Is BER testing on STEVAL-IDB008V1M possible?
I have carried out some tests on the STEVAL-IDB008V1M. In the tests I have tested how BER is affected range, interference and objects.I achieved this by transmitting hardcoded data, so on the receiver side, I knew the correct data and compared every ...
RSnel.2 by Associate
  • 765 Views
  • 0 replies
Problem with adding library to keil program
Hello to everyoneI want to print "Hello World" to the screen using the stm32f103ve card.and when it comes to the "HAL driver" section and adds the libraries to the project, it gives an error.the error is as follows: ..\..\main.c(3): error: #5: cannot...
Spalt.1 by Associate
  • 2000 Views
  • 1 replies
S-parameter for BAL-UWB-01E3 is not found
Hi Team, we are using RF Balun (BAL-UWB-01E3) in our design.For performing RF simulation we are not getting any S-parameter for the selected Balun. Does anyone know from where I can get the S-parameter or Is there any other method to simulate the Bal...
Shift by Associate II
  • 770 Views
  • 0 replies
  • 1 kudos
