Interface and connectivity ICs
Ask questions and find answers on connectivity ICs, focusing on protocols and I2C challenges on STM32 Nucleo boards and BlueNRG products.
ST KNX waveform reflection
I created a KNX communication module using ST KNX, but when the KNX Bus voltage is transmitted, the waveform is ringing, resulting in a communication error. I am using the recommended value of 68 Ω for the external resistor RTX on pin R68. Please giv...
arakawa by Associate
  • 1234 Views
  • 0 replies
BlueNRG-LP support on Zephyr
A cursory search of the internet shows the Zephyr Community decided not to port the BlueNRG-LP for use with the Zephyr Framework/RTOS.  The reason they gave (in 2023) was: "not planned".  That seemed a bit vague to me.  Though this is likely a questi...
JW by Associate III
  • 1478 Views
  • 3 replies
  • 1 kudos
Resolved! Inquiry Regarding USB PD Controller Solution to use in simultaneously Charging and Data transfer on USB Upstream port.
Hello,Our product is currently in the testing phase, and we are using the USB2534 hub IC for both data transfer and device charging on downstream port.In our setup, we are using USB 2.0 with a Type-C connector. A pen drive or mobile phone is connecte...
