STM32 MCUs Security
Ask questions and find answers on STM32 security frameworks and tools, including cryptographic libraries, TrustZone, and the Secure Manager.
Has anyone ported sbsfu on stm32h723xx ?
Hello everyone,I am trying to port the SBSFU project to a stm32h723xx board from the stm32h753xx project but I have discovered many discrepancies because the latter has dual bank flash while the former has only one flash bank.Do you suggest to start ...
Resolved! STM32H750VBT6 access crypt registers all read back zero
Hi,Developing AES GCM on a customer board that is used STM32H750VBT6 with CubeMX 6.1.1 has a problem needs help.Tested example code CRYP_AES_GCM from STM32Cube_FW_H7_V1.8.0 Projects/STM32H735G-DK/Examples/CRYP is failed. And used JLINK debug figure ...
STM32F7XXX PCROP segger embedded studio
how to use the pcrop of stm32f7xx in segger embeded studio, I found a pdf "dm00346619-proprietary-code-read-out-protection-pcrop-on-stm32f72xxx-and-stm32f73xxx-microcontrollers-stmicroelectronics",I saw the usage process, but I don't know how to use ...
wlong.2 by Associate
  • 945 Views
  • 1 replies
Resolved! Undefined symbols from libSTM32Cryptographic_CM4.a
Hi,We are migrating our code from using M3_CryptoFW_RngHW_2_0_6 to using libSTM32Cryptographic_CM4.a. Our target is STM32F405VGTx. When compiling we get a linker error from the library itself (cmox init is part of the ST lib), not from a function our...
YCohe.1 by Associate
  • 3320 Views
We are using STM32H750VB, for this please send me Crypto AES 128bit code examples, in online we got lot of crypto lib but we need example source code for this crypto AES128 bit...
[STM32L496] Jumping from bootloader to user Application with RDP enabled doesn't work without going through a power cycle.
I'm currently testing the UART bootloader on a NUCLEO-L496ZG-P, the bootloader itself works fine and i've written a python script which can upload .bin files to the controller.The problemi'm having is that the product will need Readout Protection in ...
Janek1 by Associate II
  • 2415 Views
  • 4 replies
